Encoder question
paulB
Apr 2003
171
How would you interpret encoder specification parameter of pulses per revolution (PPR)? If it is two channel quadrature encoder and spec is saying PPR=2048, does it mean that each of all channels (A, A/not, B, B/not) will output 2048 pulses per revolution, or each of the channels will output 512 pulses, which in sum makes it equal to 2048?
Thank you.
PaulB.
This may not be universally true, but generally when people talk about PPR they are referring to the electrical cycles from a single channel in a single revolution.
Once decoded the terminology shifts to 'counts per revolution' and typically includes a decode type. For example, a 2048 PPR A-quad-B encoder may produce 8192 counts per revolution with fulkl quadrature (or 'X4') decode.
Keith
Most encoders will give you the PPR per channel on one revolution. A and B channels are 90* phase shifted so you can determine direction. If it has Z and Znot,it will be one pulse per revolution each.
Each pair is 180* out of phase with the other, IE: A and A not are 180*.
When they are different and there are many other ways to do encoders, the label usually notes specs.
Due to the complexity of some encoders, 99% of the manufacturers are quick to provide you with a hook up diagram and specs.
Hello all. I am hoping someone here has installed a Danfoss VLT Midi FC 280 and connected an encoder to it. I am just trying to make sure I select...
474
Hi Everyone, I am new to srevo control, and hope to you guys can help me. I have a Siemens s120 controler and drive, drive a cylinder up and...
1,294
Hi I have a question about a gray code absolute 8 bit encoder. The encoder is connected to 8 inputs on an Allen Bradley PLC. if you turn the...
2,290
I have a 755 Drive with a Single Incremental Encoder Module. I want to have the drive running on one encoder channel (A). I hooked all the wires...
1,980
We are using an Absolute Gray Code Encoder that counts down from 255 to 0. I was wondering... we are upgrading from a Micrologix 1100 to...
1,430
