Clay B.
Try setting up a Status chart and include addresses to either side of where you think it should be. Then spin the encoder. Also note on some of the cheaper encoders you can NOT connect common to the PE or the encoder will be damaged. If this has happened then the encoder is toast.
As far as the absolute. You can order based on the number of bits you want to use and I think S7-1200 supports Gray Code. If you do not want you use one that's really up to you. Each can get the job done, its just a matter of how.
