Encoder Signal Splitter
Prince
Jun 2002
284
I am trying to use one Encoder for two separate systems.
Do you have a suggestion for me?
Do you suggest using a signal splitter board instead of a new encoder?
EPC-RXTXD-2-V3-5V-5H-5H-5H ENCODER SIGNAL SPLITER
i use that model. You can chose configuration.Cost is 250$
There are: 1. Encoder 2000 imp/rev, HTL driver, supply 15 VDC. 2. Applicator 1 3. Applicator 2 4. Printer. I need for three signals from encoder...
4,380
Hi all, I have an application coming up where I have a motor that runs forward or backward to adjust the linear position of a machine component...
1,304
I am looking to duplicate a quadrature encoder signal where the original supplies a VFD and the duplicate goes to a PLC. I have had success using...
2,104
I am trying to replace an old Relience system with S7-300. The system has an encoder that uses external 220V supply and has 12V A,A*,B,B*. As...
1,148
Motion control isn't my specialty... Lately, I have been using Automation-Direct servo packages...
3,016
