FM350-1 12v encoder signal
Prince
Jun 2002
284
I am trying to replace an old Relience system with S7-300.
The system has an encoder that uses external 220V supply and has 12V A,A*,B,B*.
As you know FM350-1 will only supply 24V or 5V encoders. Can I use the external supply and connect the A,A*,B,B* signals to FM350?
Should I try 24V or 5V for the setting?
I have a S7400 414-2 DP fw5.3 with a CP443 6GK443-1EX30 fw3.0 and FM350-2 on profinet The interface module is a 6ES7153-4BA00 fw 4.0 (ET200M...
1,913
I am using FM350-1 with S7 315-2DP. I use the counter module to count the encoder pulses and cut a crossing plate on the desired position. I do...
1,740
For a revamp we will have a configuration with S7 1500 and FM350 in ET200M on profinet. Will the FM350 work? Because I see in Siemens Tia...
2,748
Dear All, Hw config. are 317-dp cpu with FM350-2 counter modle. Connect HTL encoder A to FM module nr 5 and B to Number 8. (mean channel 1)...
1,849
We are currently encountering configuration problem with FM350-2 used for counting and totalizing functions. When we configure the FM350-2 and...
3,182
