fm350-2 not count
necyil
Nov 2004
Turkey
102
Dear All,
Hw config. are 317-dp cpu with FM350-2 counter modle.
Connect HTL encoder A to FM module nr 5 and B to Number 8. (mean channel 1)
when turn encoder forward without any problem and counted.
if encoder turned backward fm module not count.
I need your advice
many thank for all helps
I have a S7400 414-2 DP fw5.3 with a CP443 6GK443-1EX30 fw3.0 and FM350-2 on profinet The interface module is a 6ES7153-4BA00 fw 4.0 (ET200M...
1,913
I am using FM350-1 with S7 315-2DP. I use the counter module to count the encoder pulses and cut a crossing plate on the desired position. I do...
1,739
I am trying to replace an old Relience system with S7-300. The system has an encoder that uses external 220V supply and has 12V A,A*,B,B*. As...
1,144
For a revamp we will have a configuration with S7 1500 and FM350 in ET200M on profinet. Will the FM350 work? Because I see in Siemens Tia...
2,747
We are currently encountering configuration problem with FM350-2 used for counting and totalizing functions. When we configure the FM350-2 and...
3,180
