enet/b communication unreliable?
wilsonzhu
Jan 2008
vancouver
278
Hi All,
I have a rockwell ENET/B card, today It suddenly donesn't work reliable, sometime RSlinx can show all cards in the backplane, sometime it can not, what cause this happen, is the Enet card is demaged? when I ping this card, sometime packet is lost with no reply.Thanks,
Because it's failing to respond to PING, the problem is likely in the Ethernet port or in the cable or switch or another part of the network.
There are diagnostic web pages for the 1756-ENET; just type the IP address into a web browser and start by looking at the media counters.
Did you change anything on the network recently, especially on the switch to which the 1756-ENET is connected ? Remember that the 1756-ENET is a 10 Mb/s Half-Duplex device only; don't connect it to something that's fixed at full duplex.
Yes, I found one switch's port is not working properly, Thanks,
We Sometimes face problems in Rx3i device-net module talking to a servo valve controller , How we can troubleshoot the communication issues ?
1,468
hello everyone, i have an issue uploading parameters from 825-PD relay in rsnetworks for devicenet. all the other devices hase been uploaded in...
1,881
hey, this my first time posting... we´ve been working with devicenet ,I hope somebody can help or talk about experience, it has safety...
2,115
Hi! I wish a help with a problem communication. I'm trying to connect to a DeviceNet through a 1747-sdn scanner. I've been trying to connect...
1,657
Hi Once again your guidance is required.I am trying to learn how to set up the communiations between PLC on ethernet. I have two S7-300 PLCs .1)...
1,591
