Enhanced PID advice
pauly
May 2002
South Wales,U.k
244
We are trying to control a flow with the PIDE instruction in a Controllogix PLC. There is aproblem in so much that the the control valve and pipework are oversized and at full valve opening, the flow will be much too high. This then causes a fault in the PIDE instruction with the PVEU MAX being higher than the upper limit. A limit function at the front of the PIDE might do the trick to prevent it going into fault but I wanted any advice from anyone that may have come across the same issue. I am hoping tight control from the PID function itself might suffice, but there will always be overshoots.
Any advice will be very welcome
Using Allen Bradley Compact Logix L32E Processor and the PIDE (in fucntion block diagram) seems to get stuck at the low CV value and gives the...
5,437
I've come across this article on an enhanced PID instruction. Does anyone know which software they may have seen that supports it I already...
4,017
where do i find FTVIEW HMI Enhanced graphic as per attached HMI screen snapshot i had tried its library:scratch: object but they are not similar...
2,144
Does anyone have any ideas on how to build this in Crimson? The analog scale with a moving indicator and PV data is easy. What I'm having...
2,338
I am replacing a plc5/25 with a plc5/20e. downloading the same program that was running in the classic I have a block transfer error on a...
1,771
