plc5 classic to enhanced
danny.boyd
Nov 2012
Louisiana
I am replacing a plc5/25 with a plc5/20e. downloading the same program that was running in the classic I have a block transfer error on a 1771-vhsc. other block transfers on 1771-ife cards are working fine. Any ideas?
What's the error code ? Look in the ".DLEN" field for a negative number (the sign denotes an error).
Block Transfers are pretty much a universal technique, but a newer controller might run them faster or slower than an old one.
error code is -5. checksum error. found a knowledgebase answer that indicates a fix for the problem I think. It is related to the enhanced processor's speed.
I am using the following formula and I am getting error, Invalid Expression - too many closing parenthesis. when i copy the formula to notepad or...
156
Preface: Kinda long, so I made section titles Intro: I just want to see if anyone here has seen anything similar. A PLC5-40 series C enhanced...
373
Hi, can anyone help me get a pdf file for this RSP files. They are from a PLC5. Thanks
522
Hello all, I am seeing this behaviour where an integer file (N46:33), has an integer in binary (11110) which is 30 in decimal. I did a...
520
