ERNT-AQTY81 Conversion Adapter Issue.
zai_jnr
May 2008
MALAYSIA
169
Hi All,
I got problem with conversion Mitsubishi from A to Q series module.
Right now I'm using conversion adapter spec which is ERNT-AQTY81. Already check the manual..
AY81 have 2 common for 32 output point but QY81P only have 1 common for 32 output points.
For your information, AY81 use same common for its 2 common. So, I think no issue if I use existing wiring to connect to conversion adapter ERNT-AQTY81.
Existing system this card module was wiring to FANUC NC machine. When ladder Y output ON, there have no signal send to fanuc machine. That mean, fanuc machine not receive the signal.
I just wonder, what actually the problem fanuc machine cannot receive signal output PLC..
what i need to check ya?
really appreciate your reply....^^
Hi, I have a screen 'Images' with 3 overplayed images (graphic objects). On another screen I have 3 instances of a faceplate. Depending on which...
2,576
Hi, I'm trying to connect an ATV61 VSD with Ethernet/IP card to a control logix (via 1756-ENET series B card). The ATV manual mentions using...
4,939
I have been working for awhile to develop the most highly optimised communication connection between a Q series PLC and a custom VB application we...
1,568
we use different timers in Simatic S5 PLC like SF SE SS and two more i dont remember their name i know they are timer on delays and...
3,675
I have a machine which is undergoing upgradation. As part of the process two SEW drives are being replaced., existing Gen B with new Gen C. The...
229
