Error in S7
gordon
Guest
G
When I try to go into a LAD/STLFBD: Program blocks
I got a pop-up windows with text:
There is a time stamp conflict with at least one block call.
Anybody?
It means that the block you opened has called a function or function block with time stamp confilict which means the called block has been changed and the calling block is not updated. The time stamp conflict block is coloured in red. So in S7 for example if OB1 calls FB1,DB1 if FB1 or DB1 changes you should update the block call in OB1. You can do it several different ways:
1) delete the old block and call the new block
2) Right click on old block call and click update block call
There should be another way but couldnt rememeber it now...
I am kind of new to GE products, but we have several in my area. I made a minor logic change and it verified good, but when I tried to download I...
45
Hi, I'm currently having issued with a PowerFlex 252. It was working fine last week, and suddenly decided to stop working. When I go into...
121
Hi there, I'm new to plc programming and was wondering why I get this error code when I run my simulation for these temperature sensors? What I'm...
92
Hi Everyone. Not posted on here for a long time, but I am hoping someone can help me. I am doing a differential pressure calculation in a L27ERM...
460
Hello Everyone, I have a issue with communication between two different PLCs. So here is the facts, The Master PLC is Guard Logix 5069 with IP...
133
