CharlyAutomation Member C Join Date May 2009 Location Tampico Posts 8 Oct 14, 2009 #1 when I run my wonderware application appear several error messages... that say: Create table failed<<SPCVersionInfo>> and more like this... Does anyone know why it appears???
OZEE Member O Join Date Mar 2006 Location Kansas Posts 1,696 Oct 14, 2009 #2 I've never seen those errors, but perhaps a few more clues might help... Is this a new problem? Has it ever worked properly? If so, what has changed? Do you have a license for the SPC portion of WW?
CharlyAutomation Member OP C Join Date May 2009 Location Tampico Posts 8 Oct 14, 2009 #3 the application works correctly, but display those errors when it starts. I added some tags to the application and after that the messages apeared.
OZEE Member O Join Date Mar 2006 Location Kansas Posts 1,696 Oct 15, 2009 #4 There's your clue... What did you add? Are they properly configured? (Hint -- no they're probably not...)
CharlyAutomation Member OP C Join Date May 2009 Location Tampico Posts 8 Oct 15, 2009 #5 maybe, ammm how can I know if the tags are properly configured? what´s the correct procedure to add a new tag?
