esapolymat script as a function
RSJ2K
Mar 2017
spain
HI, i dont know how to use a script as a function in Esa polymath device.
I have to read and write variables from an other script so I need to call the function script. And use the variables.
Can anyone help me?
Manual
I had read the manual, but It doesn't solve my problem.
They don't spcify how to call a variable ln a script that I set like a function, from other script where I want to write in the function variable.
"Using the General mask you can set the identifying properties
of the Script. The Name is a unique attribute within the project
that is, other different Scripts with the same name cannot
exist. The Comment is a Unicode string and is visible only
within SmartClick. It is also necessary to define whether the
Script must return a value to the application and what type of
value this must be (Number, String or Variant). Use the table
at the bottom of the mask to specify the input parameters to
the function with their related Names, Types (Number, String
or Variant) and Comments (visible only in SmartClick)."
Regards,
Thank you for your time, i had already made this steps. But my problem comes now when from an other script i want to call to this other where i have set de variables and write them.
Hello. I have a db which is 1000 INT, and this db is represented in WinCC as a raw data type set of 5x 400 Bytes. This set is read with a script...
85
Hello Experts I am working on a project with WinCC Unified v16 PC system and want to create an option on the screen to export logs to the...
75
Hello, I am learning to create shapes and VB Scripts in HMIWeb Display Builder. I wanted to change color of my rounded rectangle by script. I...
124
Hello, I have a quick question. I have been using scripts to change the color of buttons. The reason, I am usually using multiple hmiruntime.tags...
129
Hi All, I'm keep getting double quotes in between selections rather than the beginning and the end. Here's the script and please help to find...
822
