ET200 SP HA DI card wiring
Lc1
Jan 2014
Uk
59
Hello,
We have the following siemens DI Card 6DL1131-6BL00-OPH1 ( 32 channel)
my question is in relation to the wiring of this card with the V50 thinktophead.
Am i correct in my thinking here:
we supply 24V from the control panel to pin 1 on the thinktop head
we supply 0V from the control panel to pin 2 on the think top head
we can then take pin 4 from the think top head and run it to a channel on the IO card for example DI.0+
Do we need any special terminals or similar for the IO module ?
thanks
Hi, I have a question regarding the DI module 6DL1131-6BL00-0pH1, i am confusing myself with the family of IO, this is a 32 channel module. Can...
990
Hello, We have the following DI card that can accept 1,2 and 3 wire DI's ( 6DL1131-6BH00-0PH1). We plan on installing this card for use with a...
1,487
Hello, We have the following DI card that can accept 1,2 and 3 wire DI's ( 6DL1131-6BH00-0PH1). We plan on installing this card for use with...
1,911
Hi all, is it safe to remove AI / AO / DI / DO card from ET200x (S) while its powered, I would like to see which OB events occur in such...
2,293
Hi I have a task to change a controlsystem on a plant. The existing PLC is a Siemens IM 151-8 with a profibus mastercard 6ES7-138-4HA00. My plan...
632
