ET200 SP HA DI card wiring
Lc1
Jan 2014
Uk
59
I have a question regarding the DI module 6DL1131-6BL00-0pH1, i am confusing myself with the family of IO, this is a 32 channel module. Can this module be used with the pulse input of an E&H flowmeter wired (1 wire) the following way
24VDC to + on meter
- on meter to say DI.0+
also if this module is used in a 1 wire configuration does 24Vdc and 0v need to be applied to 1p1 and M respectively? or is this only for 2 wire configurations?
thanks
Hello, We have the following siemens DI Card 6DL1131-6BL00-OPH1 ( 32 channel) my question is in relation to the wiring of this card with the V50...
890
Hello, We have the following DI card that can accept 1,2 and 3 wire DI's ( 6DL1131-6BH00-0PH1). We plan on installing this card for use with a...
1,487
Hello, We have the following DI card that can accept 1,2 and 3 wire DI's ( 6DL1131-6BH00-0PH1). We plan on installing this card for use with...
1,911
Hi all, is it safe to remove AI / AO / DI / DO card from ET200x (S) while its powered, I would like to see which OB events occur in such...
2,293
Hi I have a task to change a controlsystem on a plant. The existing PLC is a Siemens IM 151-8 with a profibus mastercard 6ES7-138-4HA00. My plan...
634
