ET200L-SC AI modules
userxyz
May 2002
any
2,768
Hi
I have an ET200L with an SC expansion
2 analogue input cards on slots F and G.
The weird thing is, that Physically, the current inputs are wired to slot G (G1 and G3 inputs).
F = 276...279 in the hardware configuration
G = 280...283 in the hardware configuration
On slot F nothing is connected.
On PIW280 and PIW282 I get zero ?? when nothing connected I should get 32767 in think.
On PIW276 and PIW278 I get the measurements of SLOT G ?????
How is this possible ?
No, for a +/- 20mA current input, at 0 mA the value will be zero.
For the other problems, I cant help you much. I would experiment to find out how it works. Mind you that it is quite easy to get the wiring mixed up with the ET200S modules.
Hi
Hey,
I have found the problem,
I had the analog modules on slots G and H
and moved them to slots F and G
after downloading it's necassary to shut the power of the ET200L of and on.
Then everything is as it should
thanks
Hi All, I have an ET200L module with part no. 133-1BL01-0XB0. I'm trying to connect it to a CPU317-2 PN/DP through profibus. The Problem that I...
2,268
How do I do This???? We are into PLC training and intend to show CPU Redundancy on Siemens S7 412 2DP cpu's. I have following Hardware (a)...
8,811
Does anyone have a source for old Siemens ET200L Profibus Modules? I have several that are bad and need to be replaced. I don't want to replace...
5,635
I have just installed Studio 5000 V30.11 on my Windows 11 Pro machine. First I had an "Invalid Pointer" error that required me to update Factory...
122
Hi First post here! I admit I am not too used to handle interrupt OBs in Siemens. I have a customer who has been buying a standardized solution...
254
