Et200s cpu + hmi
IM151-8 PN/DP can be Master not Slave.that for sure I never try HMI on profibus,I now you can use the DP port as MPI I use it for Teleservice.
Even though an IM151-7 is not a DP master, you can connect to an MP277 over profibus.
An IM151-8 doesn't have a DP port, but it works beautifully over ethernet.
great
Great.
So I need to take care that I choose a panel with ethernet interface.
Thanks,
Regards,
Gerry
I was trying to communicate between Siemens ET200S IM-151-8 PN/DP CPU to Rockwell Allen Bradley L73 through Hilscher Gateway NT100-RE-EN. Using...
116
Hello Experts, I have two system one ET200S and another CPU 1513- PN which are 300 meters apart. Now i want to share data between these to...
2,471
Como puedo usar las salidas analogicas en este plc IM 151-8 PN/DP CPU Ya, que no encuentro la opción NORM_X ni SCALE_X no logro sacar voltaje a...
996
Hi, I have a question for people knowing well the Siemens ET200S and Profibus. I have a ET200S with an integrated CPU IM151-7 and it is the...
2,500
Hello friends I have a problem! When using a Mitsubishi Q-cpu and Siemens ET200S I/O in a profibus configuration I don´t understand what the...
2,155
