ET200S problem with Modbus and Counter module
Jul 2006
mimon
32
hi, I have a problem with module Modbus 6ES7 138-4DF11-0AB0 and module Counter 6ES7 138-4
DA03-0AB0 C. May i use these module together with one IM151 6ES7 151-1AA04-0AB0? In standart case my communication run OK, but when I receive input signal to the counter module communication froze. When I see to the led on the modules I see, that led on the Modbus module quicken blinking when I recieve input signal to the counter module. Diagnostic SFCERR in this time indicate none err. Sorry my english is limited.
BarP
Hi all It’s been a while since I did any safety config with an S7-300 PLC and I think I must be missing something , I’ve added a 4F-DO output...
3,832
Hi, I am currently trying to test some IO on a ET200S module, I have a constant 24V on all of the Digital Input terminals connected to the...
1,432
848
I made a hardware configuration and I used IM151-8 PN Cpu and connected two ET200S stations (IM151-3).When I want transfer to ET200S first.I am...
1,783
How can I get the curret "t" in SCL dt=tnow-tprevious I dont know how to get "tnow". I am not sure should it be in s(seconds) or miliseconds. I...
2,108
