Step 7 ET200s - PID controller - dt problem
naturephoenix
Jan 2015
Vienn
181
How can I get the curret "t" in SCL
dt=tnow-tprevious
I dont know how to get "tnow". I am not sure should it be in s(seconds) or miliseconds. I know that a cycle of my OB1 is somthing like 5ms.
So any help out there?
I would recommend running your PID code out of a cyclic OB, like OB35, instead of OB1. They have a much more defined interval than OB1.
I use this to calculate the time between PID calls:
Code:
[COLOR=SeaGreen]// Calculate the sample time[/COLOR]
[COLOR=SeaGreen]// Transfer previous time from last Current[/COLOR]
#Previous_Time:= #Current_Time;
[COLOR=SeaGreen]// Transfer Current time to previous time[/COLOR]
#"Cycle_Time_n-1":= #Cycle_Time;
[COLOR=SeaGreen]// Get the new Current Time[/COLOR]
#"RD-Sys_T_return":= RD_SYS_T(#Current_Time);
[COLOR=SeaGreen]// Subtract Current from Previous to get Time in ms[/COLOR]
#Cycle_Time:= T_DIFF(IN1:=#Current_Time, IN2:=#Previous_Time);
[COLOR=SeaGreen]// Convert to Real and divide by 1000 to get time in seconds[/COLOR]
#Time_in_Secs:= DINT_TO_REAL(TIME_TO_DINT(#Cycle_Time))/1000;
I am working with S7-1200 so I don't know if there is anything similar for the ET200s. I can't use a Cyclic Interrupt because the data isn't always available in a fixed period.
I am having a step7 v5.4 program where the blocks are encrypted and locked. And the manufacturer is stopped the support. Is there any ways to...
182
Good Morning, Hoping someone with some Siemens experience can give me a hand with this one. Customer has a S7-200 cpu, which has a 6GK7...
253
HI! HOW COULD I OBTAIN THE NAMES OF THE STEPS OF A ROUTINE IN SFC LANGUAGE IN STUDIO5000? Or is there a system variable that gives me those...
343
I'm just trying to figure out the right method of adding a DO card to an existing rack. It's not the *next* open slot, but I have to move the AO...
557
Hi Siemens Experts, I am hoping someone can shed some light on my issue. I have uploaded the code from a S7-300 (317-2PN/DP) using Step 7...
690
