ET200S device name transfer problem...
tulip
Oct 2005
ist
236
I made a hardware configuration and I used IM151-8 PN Cpu and connected two ET200S stations (IM151-3).When I want transfer to ET200S first.I am using Simatic Manager V5.5 SP3 ( operate 64 bit Windows 7 ultimate).There is a Assign device name window in the Simatic Manager.but Assign device name button is inactive.Therefore I could not transfer to ET200S stations.The other problem I want to transfer hardware program to IM151-8 PN Cpu,This message is showing.Online:Cannot load the selected communication driver;File not found.Set PG/PC interface is S7ONLINE (STEP 7)--->Realtek PCle GBE Family Controller.TCPIP.Auto (Active).And in Diagnostic window Test button pressed.SR Protocol status '' access points using this paramter set:
->S7ONLINE''.I tried again but no success.And finally I uninstalled STEP-7 and installed again but no success.Is there any experience?Thanks in advance..
I was trying to communicate between Siemens ET200S IM-151-8 PN/DP CPU to Rockwell Allen Bradley L73 through Hilscher Gateway NT100-RE-EN. Using...
113
Hi all It’s been a while since I did any safety config with an S7-300 PLC and I think I must be missing something , I’ve added a 4F-DO output...
3,823
PLC in the project that I am currently working on has following GSD file but I cant find it anywhere online. My PLC is ET200S and its CPU is...
2,084
Got a new project using WinCC SCADA (V7.5 SP2) - the PLC is an ET200-SP, I've never had to communicate with one of these before (done plenty of...
2,412
i m working on an old machine that has a layout of 1 cpu 6es7 315-6tg10-0ab0 (bus adresss 2) 1 et200s 6es7 151-1aa04-0abo (bus adress 4) 1 et200s...
3,204
