ETAP1F can be used for media convertor.
obi1987
Jan 2014
lahore
114
Hallo,
Please, I would like to ask that ETAP1F can be used as a media convertor from fiber to copper and copper to Fiber in DLR?
I have attached an image.
1783-ETAP's that are not configured as a DLR Supervisor are equivalent to a three-port unmanaged switch.
Additionally, the 1783-ETAPxF fiber modules enable fiber to copper / copper to fiber media conversion.
Yes, ETAP1F can be used as a media converter on DLR.
However, it supports only multi mode fiber at 100Mbps.
Rockwell's tech note
Document ID QA19526
Published Date 11/23/2022
Summary
Using the 1783-ETAP as an Unmanaged Switch or media converter
Question
Can the 1783-ETAP be used on a non-DLR network?
Can the 1783-ETAP1F or 1783-ETAP2F be used as a copper to fiber converter?
Environment
1783-ETAP
1783-ETAP1F
1783-ETAP2F
Answer
If the 1783-ETAP is not configured as a Supervisor, then it will operate in a linear fashion. Essentially it will operate as a three-port unmanaged switch. 1783-ETAP modules with fiber ports (1783-ETAP1F or 1783-ETAP2F) can be used as an unmanaged switch that provides fiber to copper conversion.
Personnally, I prefer using the 5094 ethernet adapter as media converter.
Hi, I have tried to connect multiple PLCs through backplane and am having difficulty. I have created a path from EN2T (192.168.199) --> ETAP1F...
441
Hi All, I’ve gone through the rather simplistic examples that Rockwell has for PRP and cannot answer the question below. ETAPS are listed as...
1,764
Should include 1783-ETAP1F in my ControlLogix project (inside the sw project)? Is it necessary to make it work or it can be 'hidden' and IP set in...
1,656
Good Afternoon , It has been decades since I have done anything with Siemens . What is the Siemens name of their Servo Product Line and what...
216
hi all i am new here i have a mitsubishi smart touch hmi i.e ms-60t-pe but i cannot find a software to edit and download a program in it any help...
190
