Ethernet between SCADA and PLC
orense
Apr 2006
Norway
196
Hello!
I am going to set up a SCADA computer.
It will communicate with two plc,s.
The plc,s I use are Siemens 315-2 DP. These use CP 343-1 Lean cards to communicate with eachother and the computer.
The SCADA software is a danish one, called IGSS. It has drivers that support communication with the plc,s.
Earlier I used the same computer and plc,s. Difference is that I used CP 342-5 cards with the plc,s, and a cp 5613-A2 in the computer. The communication between these was S7 set up in NETPRO. To make it work, I had to have a Simatic NET on the SCADA computer. Then I had to set up the connection in NETPRO in the Simatic NET software, then download it to the CP card.
But now when I use Ethernet, I have been told that I can use a normal network card, the one that all PC,s nowadays has. I will use TCP on IP connection. TCP on IP connection between the plc,s I set up in NETPRO, but what about the computer???
Do I have to set it up at all?, do I need the Simatic NET software at all? Or will the drivers find the CP cards as long as I set up the CP,s IP-adresses???...
Thank you very much for answers...
Orense
You dont have to use a Siemens ethernet card to setup Simatic Net.
The onboard Ethernet NIC that you find on most comercial PCs is enough.
Instead of inserting a Siemens CP in the PC station HW setup, you insert a "TCP/IP general" or "Ethernet general" (or something like that, I dont remember but just poke around in the HW catalog a bit and you will find it. I dont have my normal PC just now, thats why).
edit:
To the last part of your question.
Yes, you still need Simatic Net. Simatic Softnet Ethernet LEAN should do the trick. It is quite inexpensive.
Hello, Sorry, my knowledge of communication protocol is limited, so thank you in advance for your answer. My question; I want to get 5 values...
867
Hi, What is the easiest way to create a Watchdog between 2pcs S7-1200 over Ethernet?
1,520
unexpected problem happening when connecting said panel to a CJ2M-CPU35 via Ethernet (was replacement of broken NT21 via NT Link). The machine...
652
Hello resident geniuses, Working on a new project that was initially slated to have a CompactLogix, but due to lead times the PM made the switch...
2,272
Hi I have two PLC AB compactlogix 1769-l16er-bb1b on the same location i need to read level sensor on the other PLC I know each one IP address...
1,300
