Ethernet Comm KUKA KRC4-AB
Maxi432
Dec 2016
Mexico
Good morning Gents,
I am trying to communicae AB GuardLogix PLC and a KRC4 KUKA Robot over ethernet IP.
First of all, when I choose generic standard module is not possible, because RSLogix 5K asking me about vendor ID, Product type, etc. and this kind of module does no have these options.
After that, I have tried establish CIP Ehternet connection using safety generic module but I do not know how to configure Connection parameters (Input Assembly Instance and Output Assembly Instance for Safety Inputs and safety outputs) 4 parameters in total.
An apology in advance cause my English is not good.
Any help is much appreciated.
Welcome to the Forum !
If the KUKA module shows up in RSLinx Classic, you can right-click and select "Device Properties" to get the Vendor, Type, Code and Revision.
KUKA should have an example of how to configure the Generic Ethernet Module object.
Hello Ken:
Thank you so much.
Yes, I see KUKA module in RSLinx and I already have Vendor ID, Product Type, etc.; the issue is when I configure a generic standard module to establish comm, the software request me these parameters but generic module does not have any option to set them.
In safety generic module I put these parameters but I do not know how to set Safety Assembly Instance
Thanks again
Hi Maxi,
what kind of communication you want to establish to the KUKA robot? Non safety and safety or only one of them?
I established both communications this week so I could tell you more about that.
If you need both communications a generic ethernet module does not work because you need the standard and safety generic module pointing to the same robot IP which is not possible.
For that KUKA provides a AOP. With that module you can establish non safety and safety.
Please see thread
http://www.plctalk.net/qanda/showthread.php?t=107384
The standard instances are:
Input instance = 100
Output instance = 101
Config instance = 102
Hi Maxi,
Please see thread
Taylor:
thank you so much for your help. I will try it today!!!!!
Hi; In a cabinet of a machine, a Fatek PLC with an Ethernet communication card is working. In the same cabinet, there is a 1 kW inverter. When...
514
Hi all, I have a project which utilizes an L-33ER CompactLogix (v32), which will communicate with a RIO rack with a 1769-AENTR card in its Slot...
793
Does anyone here on the forums have any experience with Solexy I.S. ethernet isolators? The model we are using is BXF3S010N0018. Issue we're...
1,827
I want to be able to use a 3rd party device to read the IO modules from an SLC505 without the use of the CPU. All the communications modules i...
32
15,311
we have a 525 drive with a 25-comm-f2p module. that was giving us 4 solid red light for communication. replaced module now we get port light is...
1,355
