EtherNet/IP and VisualStudio C#
Bbarnett
Jul 2013
United States
77
I have data in a C# program. What would be the easiest way to have this data readable/writable as an EtherNet/IP adapter? Does a module exist that can run my program?
I'm aware that there is open source code for EtherNet/IP, but I'm wondering if there's an easier/packaged way of doing this.
Is your goal to add your PC to the IO tree in RSLogix5000? If so, this can get a little complicated. Since a PC is not real-time capable, it has the potential of missing the RPI rate and causing the PLC to repeatedly disconnect.
A more reliable way is to read/write the data you have in c# to a tag in the PLC. As Gary mentioned AdvancedHMI makes this process very simple.
Thanks for the replies. I'll take a look at Advanced HMI.
I was hoping to add the PC to the IO tree. None of the IO would be time-sensitive if that matters.
204
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
101
So I have a sort of unique situation where I'm wanting to run a PF755 from the IO and over ethernet. Of course, this comes with it's own set of...
321
Hi all, My ethernet port on my laptop recently broke and I was hoping to just use a usb-c dongle in the mean time to go live on my PLC until I...
479
Hi; In a cabinet of a machine, a Fatek PLC with an Ethernet communication card is working. In the same cabinet, there is a 1 kW inverter. When...
550
