Ethernet IP communication with Omron using Pyramid dll
ettikudiappan
Apr 2002
Singapore
131
Hi
We have a PC application that uses Pyramid driver to connect to Controllogix PLC using EthernetIP. It uses Class 1 communication for the connection with the PC being mapped as a Generic Ethernet module in Controllogix controller. The applicaiton is working fine without using any EDS files for Controllogix.
Due to a client requirement, the PLC has to be changed to Omron CJ2H-CPU-EIP which supports Class 1 communication on EIP. We are having issues communicating with the Omron PLC as there is no generic ethernet module mapping functionality in it.
Has anybody used Pyramid drivers to communicate with an Omron PLC using EIP Class 1? If so, can you please share some psuedo code? Thanks in advance.
Managed to solve the issue. Pyramid is more oriented towards AB PLCs (even their examples are based on AB). Anyway, for class 1 communication, Omron needs to use something called taglink and has to have a Pyramid EDS file (modified to match the application).
Hi, I need to communicate omron CP1E PLC with SCADA to get the status of the machine. There is no etherent port available but an empty expansion...
1,611
Good day All :-) I am using a Micro850 Allen Bradley PLC which must communicate and share data via Ethernet to a OMRON CJ2MCPU32 PLC. I...
4,316
Hi, I have facing a problem when i tried to link NS15 touch screen with CJ2M with built in ethernet port. The following address i have set...
8,870
Hello, We have to create a communication between Cimplicity V8.0 (PC W7 64 bits) and an OMRON CJ1 PLC with Fins Ethernet Protocol. We've tried...
5,742
Hi, We have a Client with a Siemens S7 317 CPU and a Omron CS1 CPU. Both PLC's have a Ethernet card connected to it. We would like to get some...
7,263
