Omron CJ2M communication problem with NS15 via Ethernet
Storm1111
Apr 2013
KL
I have facing a problem when i tried to link NS15 touch screen with CJ2M with built in ethernet port.
The following address i have set in.
CJ2M: 192.168.250.1
NS15: 192.168.250.2
It could not work.
Is there anyone can guide me on this?
Thank you
You also have to set up a host in the NS screen using the IP address of the PLC.
Have never had to set up a routing table for this - just a host in the screen. Easy peasy.
you can only setup the IP link using either the USB or serial link to the CPU - Pain in the ---
the Screen and CPU need to be connected via E/net
Needs to be done through Tools in CXone
For making connection: NS to CJ2M via Ethernet/IP you only need to set the IP on the NS and host address.
Banker
I had to ask Omron about this two weeks ago - the method they talked me through worked.
But it would no work by simply setting the IP address - I did try that.
Are you certain?
The snip is for a CJ1M that I have working - just change PLC type to CJ2M for the current project.
oh well must have been me .
It was the Guy from Omron Syndey that gave me the answer though.
the photo's I attached was the area he led me to.
Have a good one
Hello,
I have problem with connecting NS15 panel with CJ2M CPU34 PLC. In network Type option for PLC found that I have other IP adress than IP adress set in CJ2M-EIP21 in IO Table (IP adress of PLC is 179.1.0.10). At the other side NS15 terminal has adress 179.1.0.11 and configured host with Ethernet IP connection 179.1.0.10. If I set in network Type connection 179.1.0.10 ethernet IP adress of CJ2M will this work or I have to do more to get this communication? Can somebody specify CX-NET and PLC routing procedure to accomplish this problem?
HI , Thanks a lot for the reply & help on previous topic. Now i setting up a new system with 2x CJ2M CPU13 and 2x SCU32 and the connection via...
1,772
Good day All :-) I am using a Micro850 Allen Bradley PLC which must communicate and share data via Ethernet to a OMRON CJ2MCPU32 PLC. I...
4,314
I nned to have an exemple for explicit messaging, initiate from the CJ2M to a Logix processor, not using the SLC mapping??? The SLC is limited to...
2,878
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
174
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
64
