Ethernet/IP servo drive
srsicard3
Jun 2020
CT
16
I am looking for some suggestions on good Ethernet/IP servo drives to communicate with an AB PLC. My customer has a non motion PLC but wants to add an indexing conveyor to their existing line that is servo controlled. I have been tasked with building a setup where they can send a relative position & velocity to the drive and the drive will index.
Being that it is not a motion PLC, I am looking for suggestions for this.
Thanks!
Thanks!
We use Kollmorgen AKD series for servo motion/s.
For our last project, we used a Mitsubishi MR-J4 servo drive & motor. It has AOIs that mimic the motion instructions that come with an AB servo. Some things are a little clunky, but it seems to be working well.
Depending on your torque requirements, I would also look at a stepper motor from AMCI. They have AOPs that make them very easy to integrate in a Logix 5000 PLC and the model we're using now has everything integrated into the motor so you just run power & Ethernet. What you're doing, indexing to a relative position, is a good fit for a stepper.
If you want to stick with AB there is the Kinetix 5100 EtherNet/IP Indexing Servo Drives.
Kinetix 5100 drives can be readily integrated with specially built
Add-On Instructions in Logix Designer applications.
I use JVL's integrated servo motor/drives extensively. Their MAC00-EI4 interface for EtherNet/IP is nice and simple to run small servo motors in velocity or position modes.
They only get to about 3 kW at the largest, and of course they don't use CIP Motion instructions and cannot do interpolated or coordinated moves.
But for conveyors, or simple positioners, they work great.
We've been using AB Kinetix 6000 sercos drives for years, but the world has gone Ethernet and we're slowly catching up. I've got to say, it seems...
4,961
Guys, I have built a system with this servo indexer and am using the built-in PLC. It has a RedLion G3 running with EIP and a Phoenix EIP bus...
5,016
Hello guys, I have a problem with TCP communication PLC Simatic - Ezi Servo II. I can create tcp connection, but I can't get receive telegram from...
656
Hey all... My company is looking to put together sort of a standard product or at least a canned product for doing some simple motion of up to 4...
2,142
Ok, So I have a controller from a company called "Aerotech". I purchased an upgrade to allow the controller to communicate via Ethernet/IP...
16,450
