Cheap EtherNet/IP Based Servo Systems
timryder
Feb 2007
Macomb MI
176
Hey all...
My company is looking to put together sort of a standard product or at least a canned product for doing some simple motion of up to 4 small axis. Nema 23/34 size motors. I've been looking around trying to find a reasonably priced servo system which has some sort of Ethernet based communication protocol, preferably EtherNet/IP. Other than the AB Kinetix line, does anyone else have any recommendations for an inexpensive system?
NOTE: The motions will be index time actions, they do not need to be coordinated axis.
Does it have to be servo or just closed loop?
Are you using a PLC to control the motion or prefer to have it in the drive?
You can do closed loop with AC and Stepper motors - that will keep costs down. Of course this depends on your accuracy, speed, loads, etc.
If you absolutely need servos I use Emerson EP drives because the drive controls the motion. You can use a PLC with it (talks Ethernet/IP) or just a plug HMI directly to it for control and adjustments. Their interface is really easy to understand and basic motion is all set up- just plug in some numbers and go.
Yaskawa has motion card that plugs into a 1756 rack to control Sigma series servos with AOI's in Logix. Or you could use my preferred method, Logix to an MPiec controller via E/IP.
Hello guys... Been awhile since I have been here and this is not directly PLC rated BUT I am hoping someone has done what I am trying to do so I...
5,816
Hello, I'm looking for a dirt cheap digital display + input, that would be wired to an analog input and analog output. This would be for my home...
97
Anyone know of a cheap foundation fieldbus communicator? Something like the USB 8486 H1, but one that does not cost $3k? Thanks, Trevor EDIT: I...
128
91
I want to monitor a couple signals in a place where there is no PLC but there is ethernet. I know I can use an AENTR or Flex I/O and a module but...
21
805
