Ethernet port 1769-L32E
fieldprog
Oct 2006
Burgenland
43
Hello all,
Right now I loaded the firmware (V15) into a new 1769-L32E Compactlogix Controller. So connection between controller and
laptop is allright through RS232 connector.
So if I want to go online on the controller over ethernet, do I only have to load a RSL5k - program into the controller over RS232 (setting the IP adress of the ethernet port in the program before loading) and going online after it with the Ethernet/IP driver in RSLinx?
You can go online with the controller through the serial port.
You can also use a Bootp server, which comes with RsLinx, or a DHCP server to do it. If you use either of these two methods then make sure you permanently set a fixed IP address once connected. You should not use the Bootp to assign the address on a normal basis. Only during the initial configuration
I have written an article for doing this on the Micrologix 1100. The principles for setting up the Bootp and RsLinx are the same.
DISCLAIMER - The following link leads to my site
http://www.twcontrols.com/index.php?option=com_content&task=view&id=32&Itemid=38Micrologix 1100 Ethernet Configuration
TW
Hmm, I did it like this now:
I got into RSLinx (connected with RS232), then I opened the controller in the list until I can see the ethernet port, opened module configuration, then port configuration, then I set the IP adress at static (192.168.1.10), then downloaded the program with RSL5k and after it connection over ethernet was allright.
I think that´s okay too.
Yes, you should also uncheck the DHCP and Bootp options.
Forgot about that option. It is only available on the Logix 5000 platform
I am using 1769-L32E. but I have the problem about EtherNet Port as follows; 1. When I test RUN this CPU, I/O LED green blinking. but All...
20,275
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
87
An outside contracting firm designed a machine for our company. There are several devices connected through Ethernet/IP. This includes a Panel...
194
My customer wants me to set up their industrial computer hmi running factory talk view se client in the following way. They want to use a single...
1,035
Hi there, I have a small set-up of redundancy system with 1756-L81E 1756-EN2TR 1756-RM2 but I need 3 ethernet ports for my system. I have...
1,226
