PLC Ethernet or ENT2 Port for Machine Control
PLCZ28
Mar 2010
Snob Hill
An outside contracting firm designed a machine for our company. There are several devices
connected through Ethernet/IP. This includes a Panel View Plus unit , VFDs, Kinetix servo
controllers, Stratix 5400 switch and 5094-AEN2TR remote racks. As of now there is no other
external connections coming into the machine control system.
The vendor has the ENT2 module in Slot #0 and the PLC in Slot #1. The ENT2 module is
connected to the Stratix 5400 switch and the PLC port is only connected to access
port in the electrical cabinet front door.
In the past we have always used the PLC port to connect to the switch and machine network.
When used the ENT2 module was used to connect to outside networks. What is the
advantage of connecting the ENT2 module to the machine network instead of the PLC
port?
ENT2 is a more robust module for normal traffic. Also this arrangement allows you to use 2 subnets. one for the PLC and one for the rest of the system.
Thank you for the explanation. But it seems by using the ENT2 module
that way instead of the PLC port invites more networking issues to procreate.
You didn't mention the PLC. If it's a new L8 series, there's really no advantage. The L8 on board port supports 1G, CIP motion, etc, so it's a viable machine network port. Typically, one or the other is reserved for process network connections, and the other for machine network. Me personally, I don't like to hang an HMI on my IO/motion control network. I prefer to segregate that traffic. All you need is a faulty Panelview sending bursts of traffic and affecting your critical motion and IO control.
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
87
Hi all, My ethernet port on my laptop recently broke and I was hoping to just use a usb-c dongle in the mean time to go live on my PLC until I...
454
Hi; In a cabinet of a machine, a Fatek PLC with an Ethernet communication card is working. In the same cabinet, there is a 1 kW inverter. When...
505
I'm adding an IAI Gateway with 2 axes connected to it. To an ethernet network on my PLC. So, I think the math is correct on the Input and Output...
144
Hello, I've been trying to learn this a while now and still have not found out how this works. I have an Omron CJ2M PLC and an ABB ACS 355 VFD...
245
