Ethernet Switches: Managed or Unmanaged?
mgvol
Dec 2004
Knoxville, TN
746
I have seen this come up on this forum and others; as a distributor, it is also a frequently asked question. When or why should I use a managed ethernet switch? The attachment is specific to Allen-Bradley Ethernet/IP, but it can show you how to choose between a managed or unmanaged switch, and how to gauge network performance if you are already using an unmanaged switch.
Use a managed switch if you are going to be using your network for I/O or producer/consumer comms between PLC's. I/O and producers multicast on the network and you need the advanced features in a managed switch to deal with that (IGMP snooping, VLANs and QOS).
Here is a article I found on the subject from Cisco.
I think the Cisco document paints with a little bit of a broad brush. If all the components in your segregated industrial Ethernet network can handle the maximum data rate then you can still use unmanaged switches. To say that every Ethernet based I/O network needs managed switches is a bit oversimplified.
Two things I would concede are that a managed switch won't hurt you and when in doubt go managed.
Keith
Keith
Obviously. The article is not a technical document, it is a broad generic explanation.
Keith
I didn't say that at all. I implied that one might use managed switches on a network where PLC I/O is present. Each application has its own unique requirements and should be designed accordingly.
KyleH-
My post didn't say you said anything in particular unless you wrote the Cisco document (which you may have). My post said:
However, you DID write:
The post says that users need (your word, not mine) the advanced features of a managed switch in networks with a large number of multicast transmissions.
I agree with your second post that the use of managed switches is application specific. The conclusion in the Cisco document is much stronger than that statement, however.
Keith
Point taken. Probably should have phrased it better.
You are right about Cisco's statents, after all they are trying to sell a more expensive solution.
I'm writing technical specification for a machine we will be building in the near future. The recipients of this document like to pick apart words. I've gotten a little goofy with semantics lately. I need a beer.
Keith
I see many references to using managed switches in lieu of unmanaged switches and hubs. My question is, what settings in particular are you...
3,357
Unmanaged Ethernet Switch We recently launched a new Ethernet switch that can be mounted outside the panel. Saves me time and room on the DIN...
5,458
I am adding 61 Ethernet/IP nodes to an assembly line. The new PLC will be a 1756-73 or 1756-83E. Anyone have a good ideas which switch to use...
3,745
Hello. I'm considering using DIN rail mounted, managed Gigabit Ethernet switches from Moxa...
20
4,979
Does anyone know of an IP67 field-mountable Ethernet switch that supports the Rockwell "Device Level Ring" protocol, but isn't a Rockwell...
1,330
