Managed ethernet switches
shawn_75
Apr 2010
KY
432
I see many references to using managed switches in lieu of unmanaged switches and hubs. My question is, what settings in particular are you using? Does it vary by PLC brand or do most all PLCs in general benefit for example when IGMP snooping is disabled?
Shawn
In most cases, if your switches all use IGMP Snooping, you will not need managed switches as "IGMP Snooping" does a pretty good job of managing their ports. It is when one has a lot of devices that use broadcasting which can not be turned off, like many wireless devices, that managed switches are needed. Or where there is not a proper router segregating work cells from each other and from the plant intranet.
If you still have hubs, you should retire them, I keep one for troubleshooting only, but rarely use it.
Where I work we are mostly going with managed Hirshmann switches. Another important thing to check is that you have full duplex capability on all ports. Other things needed are port mirroring and QoS (Quality of Service).
Unmanaged Ethernet Switch We recently launched a new Ethernet switch that can be mounted outside the panel. Saves me time and room on the DIN...
5,481
I have seen this come up on this forum and others; as a distributor, it is also a frequently asked question. When or why should I use a managed...
6,403
Other than Allen Bradley. Who else makes EtherNet/IP prioritized switches? I am looking for 5, 8, 12 Port 1000Base (1 gig) Unmanaged Wago and...
1,647
We have an existing, working system using GE MDS iNET900 radios for PLC -> PLC communication. They are tied to four dedicated ports in a Cisco...
2,004
Hi All I have an Ethernet IP MCC application with the option of Hirschmann RS20 switches or Eaton/Cooper 2080E-T. I was wondering how your...
3,439
