Ethernet
Alan Case
Apr 2002
Wagga Wagga
1,268
Hi, A quick question on ethernet. I just ran ethereal for a minute or so on my Ethernet IP network. All messages originate from IP addresses 192.168.210.xxx which i would expect but the destination address for each packet according to ethereal is 239.XXX.XXX.XXX. I have no IPs of this address that I know of on the network. Any ideas. Regards Alan Case
I'll bet you're running EtherNet/IP I/O connections or Produced/Consumed tags between ControlLogix processors.
I've seen the same multicast addresses when sniffing EtherNet/IP networks and that sent me scrambling for the TCP/IP networking reference books.
There is a good summary of how IP multicast is used in EtherNet/IP in the Rockwell Knowledgebase: Document A46234811
Has anyone out there had success containing the multicast traffic using VLANs? I believe that the traffic from ports that do not support VLANS propagates from VLAN to VLAN.
204
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
102
So I have a sort of unique situation where I'm wanting to run a PF755 from the IO and over ethernet. Of course, this comes with it's own set of...
321
Hi all, My ethernet port on my laptop recently broke and I was hoping to just use a usb-c dongle in the mean time to go live on my PLC until I...
480
Hi; In a cabinet of a machine, a Fatek PLC with an Ethernet communication card is working. In the same cabinet, there is a 1 kW inverter. When...
554
