Excel and NETDDE
ControlLogix
Feb 2003
Southern Ireland
62
Hi guys,
I am doing a little project to get information onto my desktop from approximately 99 PLCs and 66 SCADA applications (Intouch).
I have got the information into Excel but now I want to be able to write from Excel to some of the PLC registers.
I have looked at the code to do this but it doesn't seem to work for me (Office 2000 Pro). It appears that the Poke command etc are no longer supported. Can anybody offer me any way forward on this small problem of mine?
Thanks,
Colm
DDE - Excel poke demo sheet
I have a demo sheet you can use which was used for a Logix processor. Shows the basics for setting up data reads and a button to poke three values simultaneously.
Excell 2000 (9.0....)
If you are using RSLinx as your DDE server and are trying to poke values greater than 999 you may need to remove the thousands seperator (comma by default) from the value before the poke. Linx will not write values which contain this character.
HI all guru's, I have a Windows2000 SP4 PC with Excel 2000 running on it. I have to interface NetDDE data into Excel from various VAX...
2,436
I currently have a Wonderware application on our plant network and I am trying to display tag values in an Excel spreadsheet on my PC. After...
5,568
Hi, I'm trying to export data from a DataGrid to Excel using VBA, but I'm getting an error "Object doesn't support this property or method". The...
92
I don't know if this is the right place for the subject at least I'll try. The company has one of the oldest computers that is a master Windows...
755
Hi, I'm just looking for a simple way to make a button in excel (via VBA I presume) to toggle a bit in RSLogix 5000. I just got FactoyTalkLinx...
570
