Exchange data between ML1200 and ABB robot with 1761-net-dni
sevekeno
May 2013
Barcelona
Hi everyone, i´ve done the little project and run perfectly. This is the practice in capture images.
this is the first step, exchange I/O between 2 micrologix using devicenet.
Now i want to exchande I/O between our plc "Micrologix 1200" and client robot (ABB) by devicenet network. The robot is the master and the plc is slave.
My questions are:
- Which is the configuration in the 1761-net-dni?
- What ladder program i have to do it?
- Can i configure the buffer channel in .eds file to define tha mapped area?
Thanks in advance and regards!!
To use the 1761-NET-DNI as an I/O slave, the 'polled data' feature should be used.
The Net-DNI will read and write data tables in the MicroLogix (usually N7:xx) and make that data a slave I/O object for the DeviceNet Master.
For the I/O slave feature to work, you also need to implement a 'heartbeat' with one of the bits in the first data word. This is described in the Net-DNI User Manual.
You have a moderately complicated system; you are both messaging between two different MicroLogix 1100 controllers and connecting at least one of them to the ABB robot.
I have never used the DeviceNet interface on an ABB robot, so I cannot give you any guidance on exactly how to configure it.
Thanks Ken Roach!
I have only one micrologix to comunicate with robot. I read the example with heartbeat bit and i try it.
A last question. In the msg instruction wath "Communication Command have to configure?
Regards!!!
Gents, I've a Beckhoff TwinSAFE project in TwinCAT 3 where I've 2 EL6910 Safety controllers, and need to exchange data between them. So I...
831
Hi everyone, I'm currently finding ways to create variable that can be read & write between 2 Beckhoff controllers. Target to be achieved: 1) PLC...
2,302
Hello. I am trying to do some basic file operations (move file from one folder to another, rename file in the new folder etc) and usually I just...
2,186
I'm looking to exchange approx 50kb of data between an S7-1500 and a Melsec Q Series PLC. Has anyone ever done this? Is it even possible given...
1,612
Hi there, Can anyone suggest the solution to communicate between AB Compactlogix L36ERM controller(Which is having remote flex IOs over ethernet)...
3,677
