executing a bat file with automation runtime
hagaib
Feb 2014
israel
hey all,
i have an application that requires the start of file with a click of a button.
i am using b&r's controller with automation studio and i can't seem to find a way to do this.
there's a way to start a process but that only works on windows based controllers and not the small plcs.
wondering if there's a way to excute a .bat file that will do what i want for me
thanks in advance
Hello hagaib,
can you please specify in more detail ....
do you want to start a batch file on the controller ? I cant think of how this should work... ? What is the purpose ?
or do you want to start a batch file when compiling ? As you mention AS. AS is not used during runtime on the controller.
there is ways to start pre-compile programs e.g.
BR
BB
starting a .bat file
hey bits'bytes,
i want to start a .bat file on the controller.
my original purpose was starting a vnc application on a remote computer with a click of a button on another vnc application. i figured that maybe i can write a script that would start the file i want via ftp. i mentioned AS because there's a way to make a button start a proccess(on the controller) but that unfortunately is only for windows based controllers.
Hello hagaib
I understand it like in the sketch I made.
You have a controller with a VNC Visu (Visu-1) on a Windows-PC.
When you press a button "B" on that Visu, another VNC Visu (Visu-2) should open on that same Windows PC.
If this is the situation, I don't think you can (or should) manage this from via the VNC-Visu-1. Why you don't just start the Visu-2 via opening the VNC linked to Vius-2 on the controller ?
BR
BB
hey bits'bytes,
first of all, thanks for the responses.
you understand perfectly,
right now it's working as you offered (with two separate .vnc files for the 2 visualizations).
it was just a request from a customer to create a button on visu1 that would start visu2.
I have a GE 90-30 that is in run mode (run LED on) but the logic does not seem to execute. When online, I can see Inputs turning on and off but...
657
Hello All, First time using Schneider M221 with eco structure machine expert basic v12. Downloaded simple project in to controller without any...
1,434
Hello, we have a smart guard 600 controller, every time we have a power loss to the system, upon start up we have to connect with our laptops and...
1,447
It appears to me that Logix is improperly executing sheets of an AOI in sequential scans instead of the same scan as the main program. To test...
1,688
Greetings, I'm new at PLC programming, but good a logic - so I thought. I've inherited a PLC system, which is presently operating in the field...
2,494
