EXOR Jmobile Javascript access system values
BryanG
Feb 2005
Manchester
1,987
Newbie question for an EXOR Jmobile javascript problem. I want to access at least one of the system values, but I am stumped on which javascript to use. At the moment it is just the DateTime that I want, which I know I could get with
Code:
var date = new Date();
but the formatting is different to that I get by grabbing a TimeDate widget from the Controls folder. I can start splitting the date variable above, but I am hoping there is a way to access formatted system variables.
If you know of information about how to use javscript within Jmobile that would help as well. The Jmobile manual is a bit sparse and any javascript manuals have way way too much information for me at this stage :) Drought or drown.
Thank you for the reply and the links. I was hoping to be able to use the HMI internal value because it is automatically adjusted for locality settings. Besides there are other internal values that I also want to grab. I am stubborn as h*ll and will keep trying different formats for the code, something will work, eventually :) If Exor had a Forum I would have asked there. I will maybe have to email Exor, from the list on their website I don't have any local support, I am just 'worldwide'.
Figured it. I had to add System Variables in the Protocols section and then go to the Tags section and add the Tag for System Time. Then I could access the System Time Tag in javascript with a 'project.getTag'. There is nothing like keeping things simple :)
Love it when a plan comes together.
edit:
Except that SystemTime as a Widget is formatted, and SystemTime as a Tag is just a Unsigned Integer, Ggrrrr. So I will have to go to getting the Day, Month, Year, Minutes and Seconds individually and then format it myself. Which is what I was trying to avoid in the first place..
Maybe I am a bit thick, but I spent ages trying to get the Combo Box in Exor JMobile to work, turns out that there is a trick that doesn't seem to...
635
Any users/experts out there? I have just spent the last while trying to make an animation property work. This project has a series of images...
1,533
Any one out there in "Automation Land" using JMobile Studio from http://www.jmobile.net/ ?? We are using this and trying to do index adressing...
2,099
Currently I’m using ESA model VT155W0000 HMI and it’s communicate with Fanuc PLC. Can any one suggest can I convert ESA model to EXOR HMI eSMART07M
90
I want to program an Exor HMI using a Rockwell controller. However, when exporting the tag list from the controller and importing it into JMobile...
125
