Explicit MSG to PowerFlex40 (Multidrive)
Xian
Jul 2003
On the Road
[font=Arial, Verdana]Hi,[/font]
[font=Arial, Verdana]I'm looking for some help with a particular feature we've used with other Dnet connected drives. In the past, when a drive faults we use an explicit message to read the fault code from the drive and display it and a brief discription of what that particular code means. Over current, phase loss, etc.[/font]
[font=Arial, Verdana]In our current configuration we are running RSLogix 5000 v15 on a L32 with Dnet scanner. We have two PowerFlex 40s sharing one 22-COMM-D.[/font]
[font=Arial, Verdana]I have the manuals for the drives and comm card but I've ran into some issues.[/font]
[font=Arial, Verdana]1. When I set up the explicit message in the plc like the example (Get Single Attribute, Service Code e, Class f, Instance 17454, Attribute 1) it changes to Parameter Read as soon as I accept.[/font]
[font=Arial, Verdana]2. Will the drive return the fault code as a hex value? I don't have a drive available yet to test, but would like to get a jump on the programming. A decimel value would be ideal, in that I could use it to parse out a string message for the Panelview.[/font]
[font=Arial, Verdana]Any info, help or suggestions would be appreciated.[/font]
[font=Arial, Verdana]Thanks[/font]
Guys need a bit of help getting the instance correct for a 22comme with a PF40P. Trying to get 2 things first is the drive current amp draw...
96
I have always thought that Ethernet/IP Implicit messaging was the high speed data that is just "magically" there once you set it up, and if you...
4,616
Hi All, Ive an SLC program that messages to several other slc 505s as well as a positrack system. The SLC explicit messages the positrack every...
6,695
what i want to do should be pretty simple. I want to loop through vfd parameters for display on a oit. I can retrieve data via explicit msg no...
5,845
I am looking for good resources to learn more about how to message a NXR-ILM08C-EIT with a CJ2M omron plc. I am relatively new and will appreciate...
855
