Exporting I/O listing in rslogix 5000
Robb B
Feb 2011
BC, Canuckistan
363
I'm trying to find a way to get a CSV or other delimited text file of I/O addresses and labels from a compactlogix. I can get nice ones from Rslogix 500, but with 5000 (compactlogix) the file comes out practically useless. Any suggestions? I'm using the export function right now.
Can you explain what aspect of the export function's results are "useless" and what you'd prefer? I've done a fair bit of this sort of thing, so we should be able to figure out something that'll work for you.
When I export the data files, the tag listing doesn't have the local addresses with the slot/card. I'll take some screenshots, maybe that will explain better.
The L5K for does have what I need, assuming I read it right. Local address and data point. I had missed the L5K export feature, used to the last 4 SLC I did this for...
The file is pretty cluttered still, but I think a few find/replacing will clean the dross pretty good. I'm trying to end up with a hardcopy of the I/O listing, for other electricians to troubleshoot with.
If you don't already use it, Notepad++ is a fantastic tool for opening the L5K files.
Tools > Export > Tags and Logic Components
This should get you what you want in 5000 regardless of whether it is CLX or CPLX. It will give you all of the tags in the project including IO.
I am very familiar with Studio 5000 PLC programming. And I'm very familiar with C-More HMI programming. But this is my first time using a C-More...
317
As the title says, I'm trying to figure out a way to import and export recipe files from an external CF card to a USB drive and vice versa. I've...
498
Can anyone tell me how to export tags from PC Worx to a .csv file?
328
Hello Everyone, Happy 4th of July to my neighbors! Is there a way to edit Alarms in Excel? The native export is XML, and there is always...
812
I am working on trying to send and receive lists of BadgeIDs and User Access levels from a windows application to my system. My current theory is...
621
