Extract data from TIME OF DAY / TIME AND DATE
BNA
Sep 2003
Give
117
Hi
Does any one know how to extract hour and minutes and transfer them to a seperate word(Hours in one word and Minutes in one word) from TIME OF DAY or TIME AND DATE.
Regards
Brian
Hello BNA;
Once you have your DT variable (Date_and_Time), all you need to do ix copy Byte 3 (hours) and Byte 4 (minutes) to any memory location you need:
So, if you have defined your DT variable starting at DB10.DBX0.0, DB10.DBB3 holds the hours value, and DB10.DBB4 holds the minutes value.
Hope this helps,
Daniel Chartier
I would like to extract data from a Bizerba is50 using WebSockets or Profinet. I currently cannot find any information on the subject, any help...
739
Hi all - got an S7 classic Step 7 program. I have a variable that's a TIME data type it contains a value such as T#1h30m5s - how can I extract...
2,595
Hello guys, I have made a data collector which counts how long was light on. I made it by counter which counts minutes when it is on, then...
1,337
We are doing a proof of concept to try the following 1) get data from KepServer 2) The Data will be transformed eg: a Status code of 1 gets...
1,226
Hi, I have a SLC 500 and connected to it via DH+ is a PanelView Plus. The PV+ has an ethernet port I'm looking for a way to get the status of...
3,417
