EZTouch HMI Communications.
wolverine1981
Oct 2009
Chicago, Illinois
194
Good Evening Everyone,
I am having a problem with establishing communication with an EZtouch HMI.
What I am attempting is to communicate with the HMI using Ethernet from an H2-ECOM100 module by Automation Direct. Also I am attempting to communicate to a group of temperature controllers using Modbus RTU. So I am actually using multiple drivers here 1. Ethernet Drivers 2. Modicon/Schneider Modbus RTU.
The problem is I can communicate with one or the other no problem, but not both. The communication is split up to each screen has its own protocol.
The HMI is EZ3-T6C-E
EZtouch version 2.3.0
Tom
first thing does your laptop see both IPs on your network?
Can you go to CMD window and use ping to see the both?
Is the HMI on a private network, or on a customer network?
Private network is your own switch in your panel with the plc and HMI and other ethernet devices wired to this local switch.
Customer network is a bigger problem since you will have to get the local IT people involved, since its there switch, etc.....
Good morning Jim3846,
This would be a private network. At present time I am just connected straight from the HMI through a crossover cable to the PLC ECOM100 Module no switch to the Ethernet port. The temperature controllers I am using are using serial communication port. It seems what ever one I use as Driver #1 is the one that will communicate the other will not. no TX RX leds at all.
I have reached out to EZAutomation and they are stumped, they said they are working on this but have no luck as of yet.
Thank You For The Help, Its Very Appreciated
Tom
I'm using a keyspan USB to serial adapter trying to connect to a touch panel. I have successfully uploaded to this panel in the past with our old...
3,965
Wizards, I am trying to flash this little HMI and have a usb to serial converter from automation direct, the blue one. I setup the com port and...
527
I made a few changes to an EZTouch HMI and can successfully transfer the program and it functions properly. My issue is, if I cycle the power to...
1,219
My company is working toward standardizing HMI panels. EZTouch is the brand that has been chosen to go to. (I was not part of the debate on which...
1,694
Hello. I have been using A slc 500 for about a year now and want to expand my knowledge. I bought a used EZtouch screen from Ebay and wanted to...
4,461
