Factory reset M241
phonoplug
Jan 2024
Oxford
Hi all, I've read the thread below which is similar to my situation...
https://www.plctalk.net/qanda/showthread.php?t=127711
But I am unable to log into the webserver as its saying my credentials are invalid no matter what I try.
So what I really want to to is completely erase EVERYTHING in the PLC as if it was new from the factory. I have already reloaded the firmware via SD card but some settings from the original application still remain when I load that back in too.
Is there some hardware function to completely erase everything on it? I'm fine with opening it up if needs be to access a link or reset switch or something.
Has it got any passwords in it?
I think they have to be sent back to Schneider to get into them wiped if you don’t have the passwords. That seems to be the case with the bigger stuff. I think you also have to prove it’s yours.
I might be wrong….
Andy
I don't use M241 but from my experience with M221, loading firmware is not enough to reset the application password. Firmware being the part created by Schneider, application being the part you programmed in Machine Expert. You should trying loading a fresh application with no or known password via SD card and see if that does it.
Hi all, i have recieved some 4RF Aprisa SR+ ethernet radios from a customer to configure. Issue is that they are used and have non-default...
81
I want to factory Reset my 5380 (5069-L310) I have here in home lab. Reason being I want to make a Internal How-To video for Setting the IP...
542
I've got a G4(board only)with a MMI port problem. I do not know the IP, but I believe that port works. Is there a way to reset the device to...
557
I purchased a used Pro Soft AN-X2-AB Ethernet Module and wanted to know what is the process to reset the module back to factory. I assume it has...
1,464
Hello everyone, Anyone know how to factory reset CompactLogix L23E?
1,735
