Factory Talk ME Parameter Files
ccrusan
Sep 2020
Colorado
I have a question about parameter files in Factory Talk View Machine Edition. Can you pass placeholders in a parameter file like you can with a parameter list? This would let me not stack a bunch of buttons on top of each other. I hope I have the terminology right, but I'm calling a "placeholder" #1 etc.
For instance with a parameter list you can call a pop-up and pass multiple parameters including placeholders established when the main display was called:
{#2.PT_31X11},{#1\PT_31X11_Tag},{#1\PT_31X11_Units},{#1\PT_31X11_Desc},{X#1}
Because #2 in the current display is {::[PLC]PROGRAM:V30100},
In the pop-up, #1 is now {::[PLC]PROGRAM:V30100.PT_31X11}
I'm trying to do something similar in a parameter file in the line: #150={#2.CH_15X10}, but it doesn't seem to work. Does anyone know if this is possible, and how to make it work?
!============ Parameter File Created 2019/10/02 ============
! Parameter files are used with graphic displays to specify the tags a display
! uses at run time. You assign parameter files in certain application components
! and object properties dialog boxes. Please see the Help for details.
! Syntax:
! #replacement=tagname
! Example:
! #23=A_COLOR
! #23 in any expression in a graphic would be replaced by the tag A_COLOR.
!References the HMI database. Needed to display text.
#1={15000}
!References the PLC vessel program.
#150={#2.CH_15X10}
#201={::[PLC]PROGRAM:V20100}
#202={::[PLC]PROGRAM:V20200}
#203={::[PLC]PROGRAM:V20300}
#204={::[PLC]PROGRAM:V20400}
#205={::[PLC]PROGRAM:V20500}
#206={::[PLC]PROGRAM:V20600}
#251={::[PLC]PROGRAM:V25100}
#252={::[PLC]PROGRAM:V25200}
So I have 6 tanks with a global popup I have made. All the "typical" first level items are working find with passing a parameter file for the...
1,397
I have a question about parameter files in Factory Talk View Machine Edition. Can you pass placeholders in a parameter file like you can with a...
1,767
Hi, I am working on a an existing system and created one popup screen with a display number. When ever the tag value is equal to display number...
1,353
Hey, guys I'm working on some FT displays and I found a "Numeric Display" with the following expression: "PID\TCA6103" I thought it could make...
2,526
I am after some help with animation expressions using the parameter setup in ME. I am using ME 8.0 in conjunction with SLC 5/04 I have made a...
4,344
