FactoryTalk Alarm banner border color change
R_C
Apr 2005
93
In FactoryTalk can you change the border color to match the background color of your alarm message?
Checking the check box "Border uses background color" in the alarm banner properties did not work.
The "Back Color" of the Alarm Banner object is what is displayed when no Alarms are active.
By default, both the Back Color and Border Color are red.
You can change the Border color to anything else, and then un-check the "Border uses Background Color" box to allow the Border Color to be used.
Why there's a manual setting as well as an override, I don't know.
Every Alarm message also has a Background Color and a Foreground Color that are specific to the Alarm Message. By default the background is Red and the foreground is White, so everything on that Alarm Banner is consistent.
I think what you want is to just set the Background Color for each Alarm Message: because an alarm fills the whole Alarm Banner, it will replace the default "Alarm Banner Back Color" background.
Clear as mud ?
If I have the background color of one of my alarm messages to be yellow for example, the border does not change with the background. I have a message with a yellow background and a red border.
Oh, OK, I get it: you want the Border to match the Alarm Background (which can be different for every Alarm Message), rather than matching the default Alarm Banner Background or having its own specified color.
I don't know of a way to do this, except to draw a border and animate its color with a complex expression that matches your active alarm colors.
It's probably best to just remove the border entirely.
I'm using FactoryTalk ME version 13. I have an alarm banner that is an on top display. Whenever there is an alarm this banner becomes visible to...
904
Currently using FTV SE v12. We have an alarm banner window that we would like to pop up every time we get an alarm. Is there any easy or...
868
Hi All, Has anyone of you faced an issue like the alarms are not being shown, even when you know they are active? and upon refreshing, you see...
2,568
Panelview Plus 1000, Factorytalk ME 7.0, I added 5 new alarms to a panelview (don't like Factorytalk). All of them populate on the *Alarm...
2,281
Hi. So I made an alarm banner as a global object in FT ME, this is because this alarm banner goes at the bottom of every display in the project...
6,069
