Factorytalk alarm banner question?
jasil
Jun 2012
Building
48
Panelview Plus 1000, Factorytalk ME 7.0, I added 5 new alarms to a panelview (don't like Factorytalk).
All of them populate on the *Alarm History* page I believe it's called. The text is perfect etc.
On the Alarm banner that pops up when there is a active fault each of those 5 alarms says "spare"
It's looking at the same unassigned integer number 192, 193, 194, 195, 196.
I'm confused why it would populate fine in one area and show spare in the other are. I've recompiled and downloaded this twice with the same results, so obviously I'm missing something easy and stupid.
Your alarm banner is probably a message display object and you have to add alarm messages in two places. I have seen this done to have a cycling alarm display and still keep a history. Check under the local messages setup.
I'm using FactoryTalk ME version 13. I have an alarm banner that is an on top display. Whenever there is an alarm this banner becomes visible to...
901
Currently using FTV SE v12. We have an alarm banner window that we would like to pop up every time we get an alarm. Is there any easy or...
862
Hi All, Has anyone of you faced an issue like the alarms are not being shown, even when you know they are active? and upon refreshing, you see...
2,562
In FactoryTalk can you change the border color to match the background color of your alarm message? Checking the check box "Border uses...
3,166
Hi. So I made an alarm banner as a global object in FT ME, this is because this alarm banner goes at the bottom of every display in the project...
6,063
