FactoryTalk and non existing I/O module?
Ruskied
Jul 2018
Valencia PA
19
FactoryTalk with tag displays that are connected to a non existing module or non configured module usually displays a bunch of question marks. Is there a way to display some text (like "check module connection/configuration") instead of those question marks?? I've tried just about everything in the last few months.
Any advice would be highly appreciated.
Double-check the addresses you are using in FactoryTalk View. Is this a pre-made "faceplate" ?
If the module does not exist in the I/O tree then the tags won't exist in the controller.
But if the module exists in the controller, no matter what condition the module is in, the tag values can still be read by FactoryTalk.
I'm unaware of any Module-Defined Tag that goes to a "not a number" or unreadable value when the I/O connection breaks or is inhibited, though I'm willing to learn !
I'm actually using an emulator to test a program. All modules are faulted but only those in the module configured read only have question marks. If I change to module connection type to read/write, the question marks go away.
My intention is to show a text instead of question marks, to help the user understand the issue while he/she testing the program with the emulator. The module in question does show up in the studio nav tree, it's just not configured.
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
210
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
49
Hoping someone can give me some guidance or confirmation of what I need to do. We have a FactoryTalk SE program that I need to change the IP...
107
We are a water/wastewater plant, collecting realtime and manually entered data. We have been using FactoryTalk Historian (OSI PI) for real time...
144
Good morning! Let me start by saying, I am still learning about this type of HMI programming. I recently watched a video about recipes and how it...
99
