FactoryTalk Derived Tags Error
marru8619
Feb 2019
italy
Hello Everybody,
I'm having a problem with derived tag in FactoryTalk View Studio v5.00.
I created a new derived tag file, and the following expression is assigned to a tag:
NOT {["shortcut"]@isPresent}
With a macro, at startup I send the command:
DerivedOn "nameofderivedtag"
and the error message that comes out is:
"Unable to start expression evalutation"
and the Derived tag is not started. I verified that the tag exist and that the diagnostic command "isPresent" exist. The shortcut is connected to the PLC and the tags are readed.
Someone know how to fix it or why this problem occur?
Thank You
hello rdrast,
what you mean with:
Are you trying to start via the acual tag name?
Anyhow, I'm using the comand:
Hi guys! I have a problem with derived tags in factorytalk view. I used the derived tags to read an input tag (unit in seconds), and convert it...
2,041
I am summing some variables across several CLX PLCs to display at SCADA. The problem is on a comms failure of a single PLC results in a wireframe...
9,463
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
125
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
37
Hoping someone can give me some guidance or confirmation of what I need to do. We have a FactoryTalk SE program that I need to change the IP...
96
