Factorytalk View derived tags computation
Ptolemies
Apr 2017
Manila
Hi guys!
I have a problem with derived tags in factorytalk view. I used the derived tags to read an input tag (unit in seconds), and convert it to HH:MM:SS format. The problem is, when I display the values using text display(insert numeric variable), the HH and MM are rounded up instead of being rounded down. Is there an option to round down the results? Thanks!
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
125
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
130
Hello all, I was modifying an HMI in factory talk and went to change a go to display button using the ... to select from a list as I had done...
177
Hello, We recently upgraded our control server to a newer model. After the transition we are experiencing issues with our trend graphs to where...
121
Hi, I wanted to ask is there a way to have a visibility expression use the IP address of the HMI (Dynics, not PV) to show certain elements? The...
200
