FactoryTalk ME refresh button?
Ruskied
Jul 2018
Valencia PA
19
How would I go about creating a display refresh button?
My display is busy and some buttons update much faster than others when clicked and I'm not sure why, when I exit and start the display test again, all the buttons refresh and display correct image (up or down). Figured display refresh might help with that.
Thank you in advance.
I'm not aware of a refresh button built into FTVME. Honestly, it sounds like there is some other problem going on.
If you really need a refresh type function, you could have a button that triggers the PLC to write to the "remote display" tag to go to a blank display, and then quickly back to the display it was just on.
Go to display settings and reduce the screen update time - default is 1 s, which is long if you are displaying values that update quicker. Try that.
If it's a momentary push button then check the hold time value
For more information check this knowledgebase note:
FactoryTalk View ME: How do push buttons work
487324 | Date Created: 04/25/2012 | Last Updated: 01/11/2018
Access Level: Everyone
https://rockwellautomation.custhelp.com/app/answers/detail/a_id/487324
My screen update time is set for 0.5 seconds. The problem occurs when two buttons are pressed at the same time, one button activates in about 0.5 seconds, while the other one takes like 60 sec or so to update the button image.
We are cutting over a PLC5 to ControlLogix and we ran into some issues with the HMI (FTView v10, Network Distributed). We found that after...
951
We recently changed all our IPs on the network (from 10.0.0.x to 160.100.0.x). RSLinx Classic shows the updated list. Who Active[sic] shows the...
2,238
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
210
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
49
Hoping someone can give me some guidance or confirmation of what I need to do. We have a FactoryTalk SE program that I need to change the IP...
107
