FactoryTalk Parameter List to tag
rconig
Apr 2021
Detroit
I have a screen that can be opened by 4 different buttons. Each button loads a different parameter file for that screen.
I am passing a constant to the screen (in the parameter file) to see which button called it.
ie.. #10 = tagconstant1
now, from the screen that is open, how do I get the value of #10 into a tag that the PLC could see?
I tried to use a macro on the screen load to say that: tagint = #10 but it seems that the macro is running before the parameter file loads.. not sure if that's correct or maybe the syntax I had was wrong. any advice on a method to do this?
Why not the button writes the value to a PLC tag, and let the PLC switch the screen
if the plc loads the screen, it would always be the same parameter file - wouldn't it? I only have 1 screen that really acts as 4 because each goto display button loads a different parameter file.
goto display1 - button 1 - loads parameter file 1
goto display1 - button 2 - loads parameter file 2
goto display1 - button 3 - loads parameter file 3
goto display1 - button 4 - loads parameter file 4
is there no way from display1 screen to write a tag that says how he was called?
in each parameter file, I have included a pointer (#200) but can't figure out how to write {#200} to a tag like: "intPointerTo PLC".
I really appreciate your response
The 'Parameter File', 'Use Parameter List', and 'Parameter Tag #' entries of the Global Connections give the PLC control over what parameters are used when using the PLC to open a display via the Remote Display Number.
EDIT:
What about using the remote macro feature to have the PLC trigger your macro once the display is loaded?
All, Thanks for reading this post and for any ideas and suggestions. As stated on one of my previous post, I am in the process of upgrading an...
5,247
Is there a way I can get a parameter list value passed back to the logic? I'm using FactoryTalk Studio 9.0 ME and RSLogix 5000 v30. I have 2...
8,410
Hi all, I have an ME project (not my code) that I have to modify. The original programmer has used parameter lists (not parameter files)...
2,969
Hi Everyone, I am trying to add a constant value (such as a string) into the parameter file. I put the string in " " but it does not work. would...
188
Hi All, I'm currently designing a faceplate for an analog input object, and I'm trying to create an alarm tab with an Alarm and Event Summary...
444
