FactoryTalk SE - A few pointers
jazuk1970
Feb 2016
Derbyshire
Hi guys,
I'm pretty new to FactoryTalk (SE) but have a fair knowledge of Intouch/iFix (Yes i'm learning to forget everything I know about those for SE lol).
I've a couple of questions I hope someone can give me a few pointers on.
1. I'd like to pass "TEXT" to a macro and can't seem to do this? In my example i've an HMI tag: myTag of type memory string.
If i have in a macro (myMacro):
myTag = "Some Text"
then everything is ok however if i call myMacro "Some Text"
and modify the macro:
myTAG = %1
i get "Failed to resolve item's ID 'Some Text' because it does not exist on any server.
Clearly its taking %1 as a tag, is there anyway to tell the macro treat it as a literal string?
2. Is there any better reference material for the VBA implementation in SE?
I've seen a few posts on here about the VBA and it looks like seriously hard work compared to the likes of iFix and Intouch etc. (setting a tag value for example?)
Thanks in advance.. and hoping to avoid insanity.. otherwise back to old school long hand each time..
Welcome to the forum!
I don't know of a way to do what you're asking offhand - but then, I've never used a macro in SE, because I can attach enough commands to a standard button that there seems to be no point wrapping it up into a macro!
Can we perhaps take a step back and describe what you're trying to achieve in a wider sense? It may be that there's a simpler way to achieve it all round.
(and when I say "simpler", I mean "completely different to the way you would have thought to do it, but just happens to work really well in SE" ;))
Thanks for the response ASF.
Actually I was trying to do several things all of which are just to make my life easier (being lazy really) such as create a "generic" navigation button which i can set with parameters etc to fill in the name of the button, call the correct display to open and set a tag in the "header/top bar" which shows the description of the current display.
I have found other ways to do these things as you say putting multi commands on buttons, having multiple statements in the display "start-up" box etc. But i want to change further down the line its more work than simply modifying a common macro.
Not to worry.. i'll carry on.. I've yet to look at Alarms and Security lol.. I'm sure much fun to be had.
No doubt! Well, enjoy - for what it's worth, I have my navigation bar permanently docked to the bottom of the screen generally, so that I don't have to copy it onto every display.
Good luck!
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
135
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
39
Hoping someone can give me some guidance or confirmation of what I need to do. We have a FactoryTalk SE program that I need to change the IP...
98
We are a water/wastewater plant, collecting realtime and manually entered data. We have been using FactoryTalk Historian (OSI PI) for real time...
139
Good morning! Let me start by saying, I am still learning about this type of HMI programming. I recently watched a video about recipes and how it...
73
